[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
I ran the boat up to WOT on a couple of occasions today . . .
I probably have not trimmed up enough, as I was only getting 5100 RPM and 48 mph.
Time to plane is about 3 seconds (great improvement) and only needs about 3,000 RPM to come up on plane
I sent some performance data off to the re-power shop for their consideration.
tpenfield
Here is my chart of the speed run yesterday. The Naval Architect had estimated the 'hump speed' of 18 mph (coming on plane) of the hull in its new form using Orca software and the 3D model of the hull. Looks like it was spot on, based on my testing of time-to-plane and planing speed.
Ted, did you share the real world test with the NA? they like the feedback.
do the hondas have a limited output like some other motors until they get thru the break-in period? that may explain your lower than expected WOT. or you are slighly over-propped, considering you dont have the bilge full of beer yet.
also, still waiting for the Cheshire like grin
tpenfield
Ted, did you share the real world test with the NA? they like the feedback. I probably will send him a few pics and the data
do the Honda's have a limited output like some other motors until they get thru the break-in period? that may explain your lower than expected WOT. or you are slighly over-propped, considering you dont have the bilge full of beer yet. IDK, it is above my pay grade
also, still waiting for the Cheshire like grin . . . :LOL:
tpenfield
Quick Update. . .
The re-power guy (Mike) said to re-run the speed test with greater amounts of trim. Additionally, he asked if I could get a visual of the lower units at speed to see where the ventilation plates are relative to the water stream.
I have a camera set-up for my trailering, which might do the trick for getting a visual.
tphoyt
Now that I thought about for minute I guess people ask him to do that all day long. He wouldn’t get much done.
tpenfield
If I were Mike I would looking to go for a ride.
Mike [Preservati], (Preservati Marine LLC), most likely will be going for ride when he comes out to do the tuning. He used to be at Millway Marine in Hyannis, and went out on his own in the past few years. They deal with most outboard engine brands, but are a licensed dealer for Honda Marine and Dometic/SeaStar/Optimus systems.
redneck joe
i was wondering, and assuming, height was a wee bit adjustable.
tpenfield
The engines can be moved up a 'bolt-hole' on the clamp mounts . . . not the easiest thing to do though.
Pmt133
Just out of curiosity... which rule of thumb was used to set the initial AV plate height? I know there were a few options and I'm curious (and don't remember because CRS) what the initial height was.
tpenfield
It was about 1-1/2" in total. A balance between 1" per 12" and what made sense from a mounting perspective.
