So I am still having a problem with my VP5.7 TBI not running at peak RPM so far I have checked the fuel pressure high and low all good no ASV installed changed fuel filter fuel looks good fixed a loose MAPP sensor hose new gaskets on throttle body check plugs all looked pristine distributor no corrosion. hooked up my Tech scanner shows max RPM 2950 under load and fuel consumption at 10.91 GPH which seems high could it be the IAC MAPP sensor I get no error codes I'm getting anywhere between 10 to 14.5 max MPH could it be outdrive related?
Signed out of ideas
Signed out of ideas
