What year is my engine (Johnson)
Kramer
Bought my boat last summer, came with 40HP Johnson "electromatic" 2 stroke. I'm guessing it is late 60's early 70's. Serial #J2599852. It also says RKL 27A on it. Seller also gave me the original service manual, not that it helps me (I'm no mechanic). Any suggestions on were I might find basic upkeep and maintenance info would be appreciated.<br /><br /><br />Giddyup<br /><br /><br />Kramer
jegervais
Re: What year is my engine (Johnson)
That's a 1965. The Ken Cook Co - www.kencook.com - has reproductions of the original factory service literature.<br /><br />-John
Trent
Sorry John..Did not mean to post it after you.
Kramer
Thanx guys, replies in under 10 minutes says alot about this board!!! <br /><br />Giddyup<br /><br />Kramer
Franki
General motor maintenance stuff would be in the user manual not so much the service manual.. I believe the addredd for kencook will supply you an copy of the original user manual for $20 bucks USD.<br /><br />Its the same for pretty much all motors..<br /><br />plugs, impeller (or entire pump where necessary) decarbonize it occasionally keep the wiring clean and tight.. replace any that isn't.<br />lubricate everything after each trip out (and before) get a grease gun and keep all the grease nipples full..<br /><br />I have found that with the older outboards its not a bad idea to pull all the non powerhead bolts out once every year and lube them to stop them locking in, which is a nightmare when it happens..<br /><br />just general stuff.<br /><br />don't leave the carbs full of old mixture when you pack it away unless its had a stabilizer added or you will have to strip and clean your carbs the next season.<br /><br />get the user manual, if you already have the service manual it will go along way to giving you the rest of the info you require.<br /><br /><br />rgds<br /><br />Frank
jegervais
Trent-<br /><br />No problemo...<br /><br />Looks like I hit the "add reply" button about the time you hit "post reply" button! :) <br /><br />-John
