- Joined
- Sep 26, 2009
- 20,544
Same with my buddies Mastercraft which is on a spring fed lake....Neighbor had a big gathering this weekend he could not get his lift to drop far enough to get the pontoon to float.
Yeah we are spring fed too, guess I have been pumping too much water keeping the grass greenSame with my buddies Mastercraft which is on a spring fed lake....
I quit watering the lawn because my submersible pump quit. Must of overheated, started back up an hr later. A new pump is probably in my near future...Yeah we are spring fed too, guess I have been pumping too much water keeping the grass green
You need to have a shroud around the pump and motor to route the flow of water past the motor to cool it. You could drill a 8" well in northern WI where the ground water temperature is close to 50 degrees put a 4" submersible in there without a shroud it will burn out. Submersible motors require water flowing at velocity over the outer skin for cooling.I quit watering the lawn because my submersible pump quit. Must of overheated, started back up an hr later. A new pump is probably in my near future...
We didn't get squat out of the rain, or lack of this morning...
Gochya.You need to have a shroud around the pump and motor to route the flow of water past the motor to cool it. You could drill a 8" well in northern WI where the ground water temperature is close to 50 degrees put a 4" submersible in there without a shroud it will burn out. Submersible motors require water flowing at velocity over the outer skin for cooling.
Oh well megger it each leg to ground it under 500 ohms it is a goner.Gochya.
We've been here approx 30yrs and never touched it. Thinking it's probably original. The house is 35yrs.... So it's probably time...
What am I missing?You need to have a shroud around the pump and motor to route the flow of water past the motor to cool it.
What is the size of your well?What am I missing?
My well is 275 ft. deep with a 1/2 HP submersible in it.
No shroud.....just hang off the pitless adapter and a rope
Standard steel well casing size for around here... guessing 6"What is the size of your well?
