Lou C
- Joined
- Nov 10, 2002
- 14,679
If it's stalling at idle, it's best to rule out other causes before condemning a carb.No idea of hours I’m third owner- (for sure the one adding the least hours to it)
looking back on my previous posts I realize I’ve done nothing but chasing various issues last few seasons
I did a compression test last year which to my knowledge showed the engine to be in ok condition 175 lowest- 190 highest.
The blue smoke thing has been seen last few seasons.. usually as the boat’s been sitting for awhile.. so the valve guide seals sounds to be a likely cause!
Along with the replacement of exhaust system last year also the carb was rebuilt by the Merc shop ( they replaced impeller as well since there was this overheating of elbow (though I doubt it was the culprit as It was only one season on it / very few hours)
So if engine dying on low rpm is related to carb that would mean their expert on carbs did a substandard job ?!
As there still is an intermittent issue with fuel delivery I cannot avoid suspecting the mech. fuelpump - Yesterday before pulling the belt, Engine started without any hesitations - idling fine a couple minutes only to die..
I need to put a clear hose in the fuelline watch it as a hawk
Another funny thing is that the buzzer/alarm doesn’t sound even though key is in run position ..
Oil pressure switch was replaced last season which then seemed to solve that issue but obviously not..
couple of days ago I went through the harness under the helm - found the crimped threeway splicing of the purple wire -soldered it as an extra measure and got the alarm to go off lounder than ever..
until Yesterday when I again find it to be silent on Key on.. Oh I have tried to reseat and clean the pins in the 10 pin multi contact .. what’s next?
Start with ignition, are the cap and rotor in good shape, these can cause problems due to age and corrosion
Same with plug wires they can be checked for resistance
Spark plugs, for wear and fouling
Once your ignition system is proven good
Move on to the boat's fuel system, fuel tank vent, anti siphon valve and pick up tube the last 2 especially on older boats can cause fuel restrictions that will limit power and max rpm
If they are good, then test the fuel pump (pressure, volume, there is also a vacuum test that can be done). This is more work because you have rig up fittings and hoses to connect a pressure gauge due to most OEMs using a steel fuel line from the pump to the carb.
After all that, then suspect the carb!
