Pull start won't pull - antique engine
CFB
Hello, I wasn't very successful searching for info and found this site. Pictures attached on what I have. I bought this 40 years ago for my 14 foot rowboat - never used either. The motor was running but don't recall if it was running by the seller or if I did it myself. Kinda think the former now as I do not have a gas tank. Don't think I would have taken it off. I think I could hook up a gas reservoir just to get it going and worry about a tank later, but the top cord pull doesn't pull. I did not want to take it apart not knowing what I was getting into. I did read someplace that if something wasn't in the correct position , it would not pull. Anyone know about this engine? The writing on top: Johnson Motor Company: Waukegon, Ill USA SeriaL 147022 a-50 model.
Thanks
It should turn without anything fancy that needs to be in the right position.----Visit----aomci-----For top notch help.
tphoyt
Agree with above. You will likely find a tank there as well. Can you turn the flywheel by hand or is frozen up?
CFB
Thank you for the resource. Correct, I cannot spin the flywheel by hand nor does it budge with a cord. I wasn't sure if I could just take the three screws off on top and maybe that nut - all of them I've been able to turn - but did not know if just the top comes off just exposing the innards or will stuff pop out at me? thanks
I think you remove the flywheel by loosening the nut.----No puller required.-----And nothing will jump at you either.
CFB
The old memory kicked in saying I had the gas tank - so I went to the barn loft and there it was. Yeah! As you see, most of the decal showing instructions is worn off. But at least I have it. Took two plugs out and put in seafoam as that is what I had. Still waiting on the antique site to give me permission to post.
CFB
Engine is moving freely again!! I was able to get into the aomci forum. The soaking you recommended was the key. Just this past weekend, I applied a strap to the flywheel and with pretty good force got it to turn slightly. Soaked a few more days, applied the strap and got it spinning easily again, even by hand or the pull cord.. Not sure of the next step. I'm learning the parts of the motor as I go. thanks
Mc Tool
Envy ! That motor looks really cool . Im probly not in the best country for it but I would love to find something like that to spruce up and use .
Id love to see it going .🙂🙂🙂
flashback
You would be more apt to find a Seagull in your neck of the woods. 🙂
Mc Tool
Yep ,cant help but trip over them , still remember my Dad buying one new ...came in a wooden crate ....but , meh ,only one pot and while they are def retro Id still rather have a twin cylinder.
But your right in that they do look like a brother to this Johnson beauty 🙂
