90 hp Johnson shiny gear oil
Isaacsonnebe
Hello! I have an early 2000’s Johnson 90hp. When I was heading back to the launch I was 3/4 throttle and I lost all power but the motor was still running. At first I thought I spun a prop but when I drained the gear oil it was silver and shiny and there was metal all over the magnet. Where do I go from here? Reverse gear spins freely. Forward gear grinds and will spin with some force. Neutral functions properly.
saltchuckmatt
Try to find a good used one. Powerheads blow more than gearcases so if you weedle through the mess you might get lucky.
These gearcases are flimsy / not robust like older ones.----Take it apart.----My wildest guess is that the teeth stripped off the gears.----Your location?
Isaacsonnebe
I’m right off of lake st Claire. I was able to get my boat home using the trolling motor luckily I was right in front of the ramp.
Captain of the Double G's
Lots of parts in FL. Take your wife on vacation (lower units cheaper here and lots of them ). Now , you surprised her with a vacation so next take her to sea world in Miami( cheaper ) or something ( tell her Disney next time, maybe California ( lots of boats there too). Do it right and your lower unit troubles will be over because you will come home with a different boat.
