trooper1954
Thread starter- Joined
- Jun 29, 2018
- 92
Hi all,
Had to remove the carb on the above outboard as the fuel had been sitting in it for quite a while, and needed to be cleaned. When I disconnected the fuel pump, I noticed it was leaking, so I have ordered a new pump.
I could not remove the grey vacuum line as it was deteriorated and so cut of a small section at the end, and now I've noticed this little brass jet? in the end of the line. Of course now I don't have enough hose between it and the end to put back onto the fuel pump.
Can someone tell me if all vacuum lines have this device, and if so what it is? I'm thinking some sort of fuel metering device but ?
What do I have to do to replace this 'Thing"?
Any help appreciated.
