Just cant figure this out...
Cup420
Per a few mechanic, friends of mine, I put two cans of marine seafoam in my tank and ran the absolute stew out of my boat the other day. I think I drove a total of twenty three miles straight. Ran the motor as hot as I possibly could and kept running on full throttle. She idols beautifully, but when i'm trying to get on plane, she starts bogging down around 4000-4500 rpm. She WAS staying there for about two minutes before heading up to 5000. That actually improved. But I still have the bog and the ever so slight push push...push push. Fuel filter is clean, spark plugs are new, getting spark on all four cylinders, compression is good, carbs we're rebuilt last february, fuel plump was replaced last february, coils were replaced last february, maintenance has been kept up 100%. Vacuum lines have been checked and are strong, fuel lines are all brand new, as well. I really don't want to go through the job of tearing those carburaders down again.But I guess if I have to I will. Also I have ran nothing but ethanol free in this boat, since i've had it. Yamaha 50hp 2003 4stroke
When she bogs, hit the choke button for 1/8 sec and see if she picks up. If so, it is some sort of fuel delivery issue. If not, maybe an ign issue?
jlh3rd
It does point to an intake leak/ temporary lean condition or some kinda restriction in the idle to main fuel flow.
I'm unfamiliar with outboard ignition advance, but needs to be checked.
Cup420
Yall...I may have found the answer and its simple....the stupid bulb! I went to the river the other day and for the first time, it wouldn't stay pumped up. Im gonna say it probably went bad about 2 months ago and I just figured it was something in the motor. Well...I guess we learn as we go...
airshot
Don't feel bad, the primer bulb is one of the last things thought about when an issue arises. If suspect, best to replace the whole fuel line with a new bulb. Forget buying those gray fuel lines from walley world or other discount places. Go to NAPA and get good quality fuel hose and make your own..
Cup420
Replaced...I had grey but changed over to black
dingbat
Be careful with fuel lines from auto parts stores...been burned a couple of times before I started digging into things
For example... the Dayco hose marketed at a number of auto parts stores as 30R7 fuel line" is in fact "not suitable for gasoline/oil mixed and alcohol blended fuels" per the manufacturer data sheet.
A double whammy for those that premix their fuel
Cup420
Crap, i'm almost positive, that's what i'm running! Got it at o'reilly's! Where can I get a good quality fuel line besides the auto parts store?
Gee, I think you are chasing the wrong issue. Even lousy fuel lines take years to break down, and then the fuel filter or screen will catch the particles.
You can get good fuel line anywhere. There is an SAE rating for rubber/neoprene outboard fuel line. I probably bought my last fuel line at wallyworld. They last for decades. I change them when the outside becomes cracked from the sun.
If you really think that is the issue, get the proper OB-rated stuff at an auto parts store or Amazon.
airshot
In my area, the napa folks have always had a variety if different type fuel lines along with the technical specs to help you choose the correct one. I would never buy boat fuel hose at a discount store...not worth the gamble to save a few dollars !
Cup420
Well... I've been chasing this issue for a while. Not really sure what my problem with my engine is. But i'm thinking at this point is the bulb, which I just changed out last night. Sometimes you gotta chase to find.
airshot
I have never gotten more than mabey 5 years from cheap fuel hose, then I started buying the good stuff. Can't say I have owned a boat long enough to have a good quality fuel line go bad. Great piece of mind knowing your fuel line was not going to be a problem. Last gray hose from wallet world went bad within 3 years. The previous owner showed me the receipt for the new hose but it failed just short of three years. Switched over to the A1 fuel line for ethanol fuels, same hose as my prior boat had in it for over 8 years and not one issue. The squeeze bulbs are another issue, they seem to crack and leak long before the hose fails. I always carry a spare bulb and clamps, just in case. If you !ook close, you can see some small cracks develops before they leak. Close inspections are part of my maintenance routine.
