Digital permanent dwell readout.
matt167
I got a spare arduino I haven’t used that I got for $1, and an idea to create a digital tune up gauge for my ‘51 Plymouth ( stock 6v + ground points ignition ). I have an idea to have arduino calculate the point dwell and report it on a screen. Thinking it could calculate the RPM and display a tach too. I have a Heathkit dwell tach for actual tuneups but it would be cool to see it all the time. As I understand it, Arduino is fast enough to monitor it and calculate it but the readout to the screen would be reported in a past tense so to speak, or after the next cycle has started it reports the change or lack of
Mc Tool
Woohoo! I say go for it Dude , last time I seen a Arduino it was getting chased by a hungry Valvoline 😆
If you're into that, go for it. Me, I take one of my many dwell meters, set dwell while doing a spring service, then don't think about it again for a year
I normally set dwell while cranking as I am adjusting the points
matt167
I do the same. I just checked it Saturday and it was spot on still from last year. It is a 75 year old car with a 75 year old engine though, and it would show if anything happened inside the distributor
"The most common error of a smart engineer is to optimize a thing that should not exist."...... Elon Musk
matt167
I wouldn’t mind having a tach as well to really figure out what my max cruising speed should be, and 6v tachs are spendy as well as being too large. I just want something mostly hidden under the dash lip. I probably need like $10 worth of stuff. I might see what I can do if I get around to it. Couple other things I should do first
Pmt133
This thread reminds me I really should do a tune-up on the 55...
cheap 12 volt tach plus a cheep buck-boost. https://www.amazon.com/DROK-5-5-30V-Adjustable-Regulator-Converter/dp/B07VNDGFT6?th=1
