200hp efi overheating
workboot
2002 0t556519, in 2023 I replaced head gaskets on starboard side because of water in the 2 lower cylinders, ever since then the temp. gauge goes up above 2000 rpm. it's only on the starboard side that gets hot, I've changed water pump, poppit, rydelimed it but it still gets hot, looking at my factory manual it says there are rubber water dams between the pistons on the block. Quote "rubber water dams -if missing may result in uneven cooling of cylinders and scuffed pistons" but looking at online retailer's diagrams I cannot find them. I'm not sure that they were there when I did head gaskets. I found out about them looking through my service manual at a picture called water flow diagram. Does anybody know about these or any other reason it might be overheating. Also it does it with or without thermostats
Dukedog
those are usually called "diverters".. we would put 'em our hot rods years ago before merc ever thought 'bout 'em.. never seen 'em on any Parts charts except later model Hi Perf. 2 stroke stuff ie: 260, 280 etc... they should not be a problem.. earlier production mercs have ran for years without 'em.. when you replaced tha head gaskets did you have tha head checked for being totally flat?
i did find a dia. that shows their location but file is to big to put in a post.. can email it ya want?.. all they are is a piece of 5/16 fuel hose cut ta length.....
Dukedog
if you cut and install yourself tha length will be estimate.. it needs about 1/4" gap at both ends when installed.... these don't need ta be exact measurements......
are you getting any type of overheat alarm??? if not, i wouldn't think twice about it....
workboot
thanks for the reply, I did not check for flatness, I have a diagram in my service manual for where they go, I did get an overheat alarm once but as soon as i throttled back it stopped. On a youtube video I watched on overheating someone replied that his water pump housing had a little seepage at the base and he used a gasket sealer to stop it, his thought was that exhaust gas was getting into the water pump. I saw a little water coming out of my pump when I did the rydelime clean by didn't think much about it. I'm going to try that this Monday and see if that resolves it, thanks again Dukedog
Dukedog
when you replaced tha water pump did you install a "kit" or jus tha impeller?.. need ta replace all of it...
Dukedog
" his thought was that exhaust gas was getting into the water pump "
this is almost impossible.. water pump is in a separated part of tha motor..
workboot
I replaced the whole kit, and I do it every 3 years. As for the exhaust gas, doesn't it surround the water pump as it goes out through the prop. and wouldn't it build up pressure the faster I go. The temp gauge goes up after about 2000 rpm. Thanks again
Compression leaks causes overheating. Are you sure the head gasket you replaced is not leaking? Did you check the head and block for flatness?
Dukedog
it goes thru tha front side of tha can thru an exhaust tube thats suppose ta be sealed both top and bottom.. its completely separate from exhaust...
without it (like our hot rods) will sometimes completely destroy (melt) tha water pump....
tha tube also prevents tha discoloring of tha down housing paint from heat...
