ostrichegg
- Joined
- Dec 26, 2025
- 13
I have a Gen III cool fuel module. It has a few caps that are bolted on, one over the filter and one over the pump. It also has water intakes/outlets that pump cooling water through.
Some of the bolts were really, really corroded in there so I took it to a machinist to get them out. I'm not 100% sure what happened but I think one of the bolt holes got drilled out too far and it drilled into the cooling passage. So now, it's possible to stick a wire into the cooling passage and you can see it through the bolt hole.
So in the photo below, the cooling passage (red) travels through the casing. The bolt in the yellow hole was corroded, so a machinist drilled the bolt out. But now, you can stick a wire (aqua) through the cooling passage and it can continue down the cooling passage, but if you turn it towards that yellow bolt hole, you can also see it sticking out into that bolt hole.
So here's my question. Is this supposed to happen? If so, great! Like maybe that bolt hole is supposed to connect to that cooling passage for some reason.
If not... how bad is this? What should I do to fix this? Some options, none of them good:
1) plug the bottom of the bolt hole with sealant or JB weld or something, essentially recreating the bottom that apparently got drilled out.
2) Drill the hole out larger, and put some kind of plug in there. Maybe just some aluminum rod, and seal around it. Then drill/tap the rod so a bolt can go in but don't drill out so far that the bottom opens up again.
3) Accept the fact that water will get up into where the bolt is. Use some material that won't corrode as much as stainless. Put some kind of gasket or washer on top of the bolt so that water can't get into the fuel.
4) Get a new module. But they're like 2 grand!!
5) Something else that I'm just not thinking of?
Any thoughts appreciated.
Thanks!
Thanks!
