Best way to mount bunk boards
-JR-
Going to unload the boat at the lake so I can replace one rotten bunk board.
Will have it wrapped and ready to install. But what's the best bolt on method
Just lag bolts screws in from the under side , Or
Nut and stove top bolt going thew the complete board .
Doing the bolt&nut through method , I have to be right on in the spacing before covering with carpet . And having a hole threw the board will allow water into the wood ,but using a lock nut it should never come lose.
First method is the easiest just place covered boards on trailer and screw in some 3/8 inch lag bolts from the bottom side with some silicone
But will the lag bolts come lose always.
What is the bast method ?
JessicaKK
I’d probably go with the through bolts. It’s a little more work, but I’d feel better knowing they’re not going anywhere. Just seal the holes really well before putting the carpet on.
airshot
I vote for the thru bolts as well. I also do not add carpet to the underside so water can come out of the wood and slow down decay. With no carpet on the bottom the wood can breathe. I also use nyloc nuts so they don't vibrate loose. Use stove bolts to prevent any gouging or wearing thru the carpet from the bolt head.
JessicaKK
That makes sense. I especially like the idea of leaving the bottom open so the wood can dry out. I hadn’t thought about using stove bolts to protect the carpet either. Thanks for the tip!
countersink carriage bolts, then backfill the countersink area with caulk
redneck joe
for bunks, i like bunk slicks no carpet. you loose the 'stickiness' of the bunks some people like.
Stinnett21
I'm the original owner of a 2002 21' that I trailer and has many hours on it. I replaced my bunks once. They are attached with lag screws only. Never any issues. Occasionally I go around and feel the bunks after launching. Rarely does anything need tightening.
Kosmofreeze
My 2001 MetalCraft trailer still has the original bunks and carpet. Bunks still seem solid but the carpet needs to be refreshed. It's a 7000# boat. I see carpet specifically for boat bunks - is this "marketing" or is there more to bunk carpet than meets the eye?
Stinnett21
I bought mine from my trailer manufacturer. It came already cut into strips that closely matched my boards and was of higher density than what I found at Home Depot etc. Some buy the Home Depot stuff and put two layers on which could work also. I rounded off the edges of my boards with a sander so they would less likely cut the carpet. I cut the width of the carpet down to where it IMG_1700.JPGonly wrapped a small bit on the bottom side so my steel bunk supports wouldn't be resting against wet carpet
JessicaKK
I’ve wondered about that too. From what I understand, there’s definitely a difference between regular carpet and carpet made specifically for boat bunks. I’d probably stick with the marine-grade bunk carpet since it’s designed to handle water, friction, and repeated launching. If the bunks themselves are still solid, replacing the carpet sounds like a pretty straightforward refresh. Your Chris-Craft sounds like a beautiful boat, by the way!
flashback
I don't use any carpet, boat slides easy enough on the bare wood. No bottom paint on boat
