Alignment Tool for Aplha One Gen 2
damo79
Could someone please confirm if the alignment dimensions in the link below are correct? I had a part machined to these specifications, and it is very tight at the end.
Look in the stickies. The information is there
damo79
Thanks, checked before but images for some reason were not displayed, now i see it.
I checked engine monuts on transom, and one side looks lower than the other one.
And fiber washer (f) is it that black washer on my photo or is it missing.
Agree one side is higher than the other, and Ill guess your assembly is the newer style that doesn't use the wound washer. Do both sides have the same bushing installed with the knurled edge on bottom?
damo79
It is newer style and what I meant asking for was a rubber washer (a on picture post 3). The one is on photo looks like plastic or this rubber washing is missing.
From top it looks like this.
I will probably have to lift back of the engine and see why one side sits lower
damo79
Found also this checking transom drawing. Not sure but seems that its either u-shape type like I have or normal washer no. 7
Still need to figure out why gaps are not even or should it sit flat on washer.
muc
"Retired" Association of Marine Technicians...
Yes there is a problem with those rear mounts.
Based on your Transom S/N, this should be a Design III motor mount set up.
It will use the #7 on the right in the jpg you posted. This is rubber and called a Slotted isolator in the service manual. There is no fiber washer.
The ear on the flywheel cover (the part that has the motor mount pressed into it) should never touch this during normal operation. Might want to take a look at the front motor mounts. My guess is that someone forgot to bend the locking tab on the bottom adjusting nut and it has spun itself down. Look on the side that has too little of a gap.
damo79
The boat was shipped from Canada in a container. Due to its size, the container is tilted on its side so the boat can be loaded and secured. The container is then placed back upright for transport, meaning the boat travels across the ocean on its side. That’s likely the reason why the mountings look this way.
Drive was easy to remove and install so it never crossed my mind to check alignment properly.
muc
Interesting, I had no idea boats could be shipped on their side. If this is common practice in the EU, I would suggest that you contact a local boat dealer and ask how to correct these mounts. As far as I know, this engine will never align properly with the rear mounts in this condition.
Racing cats are shipped and trailered on their side.
muc
I’ve never worked on race boats, but I have worked on wannabe race boats and they all had solid mounts or at the very least special hard mounts.
damo79
I temporarily put an SS washer under the rear mounts as they were too low, and there was no way to get the engine aligned. It sits even on both sides and the gaps are bigger after putting washers. Today I tested the boat with the new prop as well and it runs great. Is there any way to get the rear mounts replaced without pulling the engine out?
Nope,.... It's gotta come out, or maybe slid ahead 1/2 foot, or more,....
muc
What he said.
I haven't had to replace any that are this new (already have the updated knurled design) but it is very common to need the washers when updating to this style from the old style.
When you did the alignment, did you rotate the engine to 12:00, 3:00, 6:00 and 9:00 and recheck at all 4 positions?
The pictures you posted of the mounts show them to be very different in height. If those pics are accurate, I would think it wouldn't be possible to get a good alignment.
damo79
Yes I checked each position by rotating engine shaft 90deg each time. There was difference in height on picture because that time front mounts were not set at the same hight one side was like 10mm higher then the other. But after getting them even lowered front mounts max in and still couldn't get engine aligned. Back mounts had to go higher so removed bolts tilted the engine on front mounts and managed to get washer between transom and engine mounts then put and tightened bolts. After that had enough height to adjust front mounts. I know they should be replaced.
muc
If you have good alignment and those rear mounts don’t move more than 2-3 mm when you first go from idle to WOT in the water —- rear mounts are good. But I would recommend rechecking alignment in a few months to make sure.
