Repowering my old 16ft aluminum boat thinking of going 4 stroke but have a question
Hi All i have a 1976 springBok 16 ft boat that’s similar to the starcraft ss that has a 76 johnson 85 v that unfortunately doesnt have power tilt & trim and i hear it can be hard to find the factory unit . I’ve looked at the power jacks like bob’s or panther but there $1600-2700 here in Canada . so unless i can find a used jack plate it doesn’t make sense to spend that much . I’m thinking of repowering with either a 2 stroke from the 90s like a yamaha or johnson or a early 4 stroke from early to mid 2000s
My question is if i go 4 stroke do i go up in power from my original 85hp johnson or go down because of weight. Would a 60hp 4 stroke be enough for a mostly fishing type boat
this is a project boat and i’m redoing the floor with 1/8 aluminum checker plate and redoing the transom sealed with west system epoxy so that will be able to handle the 4stroke
A 1976 motor would not be prop rated.----Your location in Ontario?
airshot
Buying a used 4 stroke could be a big gamble, the reason being is they are " very expensive to work on" where two strokes are pretty cheap and simple. I am an old two stroke fan...I have a 16' Sylvan side console with a 40 hp two stroke that dies 31 mph. Moving up to a 60 up four stroke would gain me about 5 mph and 6K or more in cash. Would need to save an awful lot of gas to make up that 6K. Other than extra weight, the newer 4 strokes are pretty sweet, but used ones can be a gamble like anything used. Just so darn expensive to repair if something goes wrong.
airshot
My local dealers tell me that if a major problem arises under warranty, they just swap out a short it long block rather than actually tearing down the motor to make the repairs. Faster to swap out a short/ long block than the labor to tear down and rebuild a four stroke....
yes i’m in ontario my old 76 johnson doesnt hsve power trim or tilt which i need because alot of our lakes are shallow and spending $1500 plus on a power jack doesnt make sense . Ive seen a few 60 hp 4 strokes going for 3-4k on facebook. I just wonder if it wasnt enough power to push my 16ft boat at a reason speed . I cant afford a 4 stroke with more hp as people want like 5k . if its not enough ho i just look for a nice yamaha 2 strokes
I’ve seen a few 60hp 4 strokes going for 3-4k on facebook a good running late 80s to mid 90s 2stroke around here is easily 3k especially the older Yamaha’s. seen a few Yamaha 2 strokes going for $4500. I just figured for around the same price why not move up to a 4stroke with no smoke , having to mix oil and gas and the hard cold starts . . I’m just wondering if a 50hp-60hp would be enough for my 1976 16ft boat that’s mostly going to be a fishing boat
matt167
I did just that. Took off an old Johnson 40hp and rigged a brand new Suzuki 25hp. The actual difference is about 10hp less but it didn’t actually loose speed because the engine runs a higher RPM. It lost much of its snappiness but I’m not towing a skier either. I don’t regret it. Quieter, smoother, no smoke or smell.
