2018 Mercury 40 EFI – rhythmic RPM surging at WOT after 5 minutes – video
ryanagler
Serial 1C563963, runs perfectly for ~5 minutes at full throttle, then RPM oscillates very rhythmically about 2 cycles/sec, no warning horn, immediately clears if throttle is pulled back and reapplied, but returns. I've tried a completely different fuel tank, bulb, and bypassed the fuel/water separator, same result. It just started randomly the other day, any ideas?
My first thought is weak fuel pump
I would suggest putting a pressure gauge on it to see if it's falling off
ryanagler
Thanks for the suggestion, I just ordered a gauge, should be here Friday. My understanding is there is a Schrader valve to attach it to, I'll take the cowling off and watch it out on the water
dog22
Sounds like a fuel or air problem. It's not getting enough fuel, which can indicate a bad fuel pump or a clogged fuel filter, or it's sucking air from somewhere else rather than the intake- a bad seal or a vacuum leak somewhere in the engine block
Lou C
Another possible cause might be a clogged screen (if it has one) on the fuel tank pick up tube.
Also look in the stickies, there is a nice section on troubleshooting your boat's fuel system that goes through all the pressure tests, vacuum tests, clear hose test, etc. All good to check and rule things out.
ryanagler
I replaced everything fuel related up to where it enters the engine. Tomorrow a fuel pressure gauge comes it will be interesting to see what it shows!
OutboardBuddy
I’m interested to know what your fuel pressure reads? Was it the blocked VST screen?
If the fuel pressure is good, it’s very possible what you’re experiencing is an ECU rev limiter.
Best
Simon Higham
Outboard buddy.
