redneck joe
- Joined
- Mar 18, 2009
- 16,208
any real difference between brands? Its bout time to do both of my new decks, if it ever stops raining here...
Not sure about brands, but the formulation makes a difference.any real difference between brands? Its bout time to do both of my new decks, if it ever stops raining here...
yeah only penetrating - same with sealing brick. Nothing surface coat.Not sure about brands, but the formulation makes a difference.
For long term durability you want a penetrating oil, not “waterproofing” like Thompson.
Been using Flood, CWF-UV since my deck was new. Still looks great after 25 years
yeah only penetrating - same with sealing brick.Not sure about brands, but the formulation makes a difference.
Probablywould OTF work?
guess I had better luck, mine doesn't look too bad after 4 years, a bit of mildew this year with all the rain.I’m a big fan of Penofin.
I used the Austrian timber oil last time as it was on sale but I won’t be using it again. I only got one season out of it and what is left will need to be stripped off now.
Here in NJ, some oil stains are outlawed.
Where did you read that?According to the internet, that stuff is water based. Says it penetrates but allows the wood to weather to a grey color.
I read the description of the product on Amazon. I was surprised that it was listed, as I expected a stain to protect from greying.Where did you read that?
Greying is typically a UV issue
