Fuel leaking out of the throttle (butterfly) shaft
Joshto
I took down my 3.0's Mercarb to investigate the fuel leak from the throttle shaft, and I'm not sure the shaft play is bad enough. I tested pumping the carb manually (while it had gas in it) and spraying a bit of WD40 on the closed butterfly; anything that drips on the butterfly eventually leaks out through the shaft....is the shaft's exit point missing something outside to prevent gas from leaking? I dont see a brass bushing, but I guess it can still be replaced?
To clarify, the leak happens after turning off the engine or when the boat is off but moving (i.e. being trailered). Fuel drips from the venturis and floods the engine (mainly affects hot starts, 15 min after turning it off). I think I know why it's flooding (the needle seat washer wasn't fully centered). Once I fix the flooding (replace the seat washer with the red fibre washer that came with the kit), all gas should stay in the bowl unless sucked by the engine. So it should not drip anymore. However, if fuel can go out, unmetered air can be suck in through the shaft.
I'm wondering if I'm chasing a ghost with the shaft play. thoughts?
  • 20261008_172520.mp4
Scott06
Float bowl is over full and leaking over. Needle and seat , float not working or too much fuel pressure
Joshto
Yes I agree. But my question whether the shaft letting fuel out is okay..I'm fixing the flooding, as mentioned
Scott06
If you fix the flooding from the bowl you won’t see fuel on the throttle shaft. Shaft isn’t letting fuel out its dribbling down the bore and across the shaft. While after a lot of use the shaft can wear and create a vacuum leak, this is in cars with a lot of miles on them. Can almost be sure the shaft is fine just fix the fuel bowl level issue
nola mike
I'm actually not sure that this would even be unmetered air. Air is coming in before the venturis so it should draw additional fuel, mixture would still be correct. If anything if would act like the throttle is more open
Joshto
I Fixed the seat washer. I'm bench testing the accelerator circuit before out it all back together and I don't understand... why no fuel comes out of the discharge hole when the spring and t are pressing down? I recorded a video but seems to big to attach. See the link
Joshto
The plunger seems perfect...it fits snugly.
Scott06
it is unmetered, the throttle shaft is below the boosters and the idle and transition circuits. If you are into classic cars some carbs like the Q-jet are real prone to it and very common to have to rebush the throttle plate. The rochester 2 jet like on my 65 gto the throttle plates are cast iron shaft is brass so the shaft gets replaced, revry rearley does it need tobe rebushed.
So even in good shape a little will leak air in but with the idle mix adjustment its normal, only when you get a large amount of air does it start to affect idle quality
Scott06
check ball missing or stuck . Depends some have check ball in bottom of well that pump goes into. When pump pushes check ball prevents fuel from getting passed back to bowl. There is also a check ball in the discharge line below the staked metal T in there. these can get stuck and not allow fuel to flow. This ball keeps fuel packed in the supply passage to the accel pump nozzle
nola mike
You're right, for some reason in my head I was picturing the choke plate/shaft.
Joshto
the accel pump has no affect on the fuel coming out the throttle shaft
Sorry, I posted from my phone, and it put the comment in the wrong thread. I meant that no gas is coming out of the discharge hole, even though the plunger is in great shape.
Joshto
Yeah, everything is there...steel ball, spring, and T retainer.
Anyway, I spent some time sticking a needle wire (came with a kit) in both directions of the accelerator circuit (from the well and from the discharge hole) and injecting fuel at high pressure with a syringe from both directions. I also slightly expanded the spring around the plunger. After all that, fuel started coming out with the expected pressure. I put the venturi back in (after cleaning it thoroughly) and tested the full acceleration circuit. It's all good now.
I'm going to reinstall the carb in the boat and run it for a while to ensure it is no longer flooding (I put a new needle seat washer, and the float re-adjusted millimetrically again). Hopefully, as you said, once the flooding goes away, the oil leak off the shaft will stop too.
I'll report back once tested.
Scott06
if you had that much crud in the passages, get a ultrasonic cleaner (cheap off amazon etc is fine) and use it to clean the carb- when i got mine, my carb rebuilding quality improved dramatically
Joshto
I cleaned this carb deeply when I rebuilt it about two months ago. Today, nothing came out- no dirt or anything on the wire....I don't know what changed, honestly. The issues I have been dealing with since rebuilding are the flooding and its consequence: a leak off the shaft. Other than that, the carb works fine... it idles and accelerates fine.
Scott06
There are a lot of cheap chit carb kits out there. mikes carb parts is my go to place for mercarbs Kits .
might have been the check ball stuck I there.
I had a situation a couple years back on my 65 gto. Had a relatively new edelbrock 1406 on it, took that off to put a tripower on it (3 x 2 bbls carbs), put the edelBrock in the box it came in on the shelf for 3 years. Was building a new engine for the gto took the tripower off the old engine still in the car… out the 4 bbl back on would not idle. Had to clean it it and rebuild it… just sat there for 3 years
Joshto
Finally got a chance to test the boat; it accelerates perfectly, but the flooding continues, and without evidence (I have no way to measure it), I'm convinced the pump's pressure is overwhelming the needle.
I found this thread here where the issue was a missing "shim" between the pump and the block. I checked the catalogue, and it lists only one gasket: 8M0108647. However, the picture shows it's actually a sandwich gasket. One thick in the center, and two paper-style on each side.
I took the pump down and found the center piece intact, but the other two parts are completely collapsed (I'm not sure if this is normal due to tightening and engine heat). Between the paper parts and the thick gasket, a plastic film keeps them from sticking together.
I wonder if that (collapsed paper gaskets) would cause my symptoms? I understand that the farther away the pump sits from the engine, the less pressure it pumps. I forgot to take a pic of the mark on the pump lever. I'll check the manual too.
Edit (add): I found a brand new gasket in my garage from a set I bought a few years ago. The kit has the two gaskets on the right; should I install them both?
Scott06
That looks like essentially the same thickness as what you removed so you can install them if you like but don’t see it changing anything. You need to measure the fuel pressure to see if it is in spec , if it is then you have a float or needle seat issue. If not in spec you need to replace the pump.
to continue the parts cannon approach, if you are confident the needle seat and float are correct , replace the fuel pump.… if you can rig a T off the fuel line by using flare fittings and some hose to measure this would be best
Joshto
I dont think it's a float/neeadle seat issue because 1) the needle and seat are new (and I just installed a new seat washer), 2) the float weighs exactly 9 grams and is adjusted millimetrically to the specs, and 3) I tested the pressure it takes to open the needle when closed with an air pump (it resists about 10 psi before it opens with the float resting on it - air horn upside down). So the needle is holding properly (provided this test is reasonable)
I'm losing my mind over this. Spent the entire summer dealing with the carb. :(
I guess I'll have to find a way to test the fuel pump pressure.
Joshto
The OEM pump from Mercruiser comes with two gaskets....😕 But the manual only mentions one, and it asks for it to be coated on both sides with Perfect Seal.
