Mercruiser Engine Serial Number Decoding
Mark R.
I'm looking at a possible boat purchase.
It's a 2000 model with either a 5.0L or a 5.7L Merc V8.
I should be able to go and look at it later this week.
Meanwhile, the seller sent me the engine serial number.
Is there any way to tell the displacement from the S/N.?
The engine serial number is 0L635389...
Thanks.!
Mark R.
I had already checked that website (as well as some others).
I see both 5.0L and 5.7L when I enter the serial number there.
Here are the results that come up:
The serial number range can be either and only Mercury data base has the actual breakdown. Either @muc or @Fun Times might be able to verify. You could also call a local dealer and they would be able to advise.
Another way is find the block casting number and then look it up on
https://www.mortec.com/
look at the block casting number to verify displacement.
the 5.7 will end in 880
tpenfield
Not sure there is much in the S/N that can be decoded, so usually you have to have a second source of verification, as was done in the posts above.
Mark R.
It was a 5.0 2 BBL carb when it left the factory
What are you basing that conclusion on.?
Is that coming from some type of database.?
Thanks.!
Mark R.
I do plan to check that when I finally get a chance to see the boat in person.
Are there any other outward indicators available (i.e. visual differences).?
Just wondering if there's anything else I might be able to discern from a photo...
Fun Times
Thanks.!
Yes…plus your engine model number against the serial number on record is 4M11025LS which if you search the number online helps some too.
