On a ‘94 Johnson v4 looper- tracking a cold hard start condition, excessive smoke at startup, and lean sneeze. Started suddenly late last year. Runs perfect at speed. Compression is ~118-120 across all.
Hadn’t cleaned the carbs in a few seasons, so Rebuilt carbs this spring with OEM kits after cleaning with an untrasonic cleaner, checked that the bowls are flat, floats level with the lip of the bowl.
Haven’t checked the record valves themselves, but the hoses seem ok with no appatent leaks testing with carb spray and propane.
Had an indicator of a possible leak in the intake to manifold gaskets, so replaced them.
Idle in the flusher won’t drop below 1200, it coughs and sneezes, with. Excess smoke. In the water is better, but still not right.
Starting to look at other possibilities and exploring the QuickStart circuit. If I probe the white/black wire on the power pack with it disconnected from the temp sender, I get a short to ground. It’s my understanding this should be open and the temp sender supplies the ground to exit QuickStart. Is that right?
