I was just checking on getting it powder coated. You think Epoxy Paint would be better?epoxy paint it and spray with rhino liner to prevent future corrosion
You imply that the oil pan had been leaking due to too much crowbar use on the sealing surface? Gee, I hope new gaskets will fix that leak, but I am skeptical.I thought it had rusted through too based on how much oil was getting in to the bilge after one day on the water . I guess a sustained oil bath on the outside saved it
Once I got it off off the block I found it is solid; albeit a bit roughed up on the seal surfaces from someone using a crowbar to remove it in the past (motor has been rebuilt at least once as I found it the have forged pistons and what looks to be a performance cam) There is the riveted on port for the dipstick and the seal on that is shot. Combine that with a shot rear main seal it would get bad.
Cleaning it up now to fix the flange damage and use rubber gaskets; should be good.
One thing is I thought marine pans needed windage trays due to sustain high RPMs but this pan doesn't have one. Even searching online I see it mentioned for this block.
A little heat, some light welding, and a flat fabrication table should save it.You imply that the oil pan had been leaking due to too much crowbar use on the sealing surface? Gee, I hope new gaskets will fix that leak, but I am skeptical.
Probably depends on what type of powder coating. Both ways are generally considered good corrosion resistance, I jdon't have experience with powder coating to know if it would be better. When restoring classic cars, blasting to bare metal and using PPG epoxy primer then top coating has given me excellent results for decades. I would lean this way because I can do this in my garageI was just checking on getting it powder coated. You think Epoxy Paint would be better?
Powder coat is porousI was just checking on getting it powder coated. You think Epoxy Paint would be better?
you will have that issue with paint as well (oil contamination). Yes a lot of engine builders will bake the block heads and intake so the paint will adhere.Thanks. I also learned that an oil soaked pan can't really be powder coated w/o an extensive bake (like 24 hours) to burn off all oils before coating, and the inside can't be coated at all. Thanks for pointing to PPG @Scott06. I was not having luck finding anything but RustOleum.
