Looking at a 1990 Sea Ray 24’ Laguna Center Console, how to inspect a hull/things to look out for?
Mwilson18
Going to check out a center console that appears to have sat uncovered for a couple years. 1990 Sea Ray Laguna center console, 24’
I’m inexperienced with hull inspection, aside from the basics of looking out for cracks and transom flexing. I’m more-so concerned about the wooden stringers/framing members, as I’ve read that this model didn’t particularly preserve them well during production (and sitting uncovered particularly worries me)
What’s your go to buyer’s inspection for detecting these warning signs? Anything to look out for with this model/year in particular? Any help is greatly appreciated!
MikeSchinlaub
Ensign
Honestly, after 35 years you should just expect all of the wood to be rotten anyway.
Look in the engine bay and ski locker if it has one. Look at the condition of the stringers, motor mounts, and transom if you can see them. It should be pretty easy to tell if there has been water intrusion. If you even slightly suspect it, assume everything is rotten.
Mwilson18
Good to know, wasn’t sure if any of the members would be exposed. It’s a bit of a project boat so I suppose it wouldn’t hurt to suspect the worst!
tpenfield
Given enough time water soaks through fiberglas. Additionally, during the manufacturing process, lots of holes are drilled in the bulkhead and stringers.
Bring an ice pick and see what pokes through. I agree with the others - you have about a 95% change of finding some level of rot in the structure.
Good on you for knowing it is wood.
Mwilson18
Will do! Seems like rot is an even likelier scenario than I thought. Thanks for the reply
Boats are designed to last 15 years
A 1990 searay will guaranteed have rot unless it's never been in water
Start with link 14 in the stickies
