MikeSchinlaub
Ensign
- Joined
- Jan 14, 2025
- 993
Man, oil is a touchy subject, isn't it? I guess it's a good thing I'm not an engine nerd, just the regular kind!
I must have missed that as well. The merc and Yamaha/Honda oils were on different ends of the spectrum for foaming, and also corrosion, and weren't great for shear stability. T4 did well on everything.Guess you missed the part about better reduction in foaming and corrosion protection in humid environment
Where do you get that?And still a worse performer on flat tappets. Go figure.
He has another video breaking down that more zinc =/= better protection. I'm see if I can find itWhere do you get that?
There was a white paper done a while back. Took a bunch of cams in, I think small block chevys. (Note lake cites this test constantly) and then run and put under a scope and wear and particle counts measured. The diesel oils constantly had ~double the wear rate vs even current API formulations at the time. My own testing indicates the same, diesel tends to show the worst performance in gas engines and it's kind of why API went and reformulated current oils for lower detergent levels, particularly calcium. Current formulations have more than enough zinc and lack of calcium to support flat tappet engines. I would still use a break in oil for a fresh break in, but the required film strength at the interface is strong enough to support any engines already out there, broken in, with them in it.Where do you get that?
Lifters that are flat steel against the cam lobe, there is no roller bearing as in a roller camWhat do you guys call a flat tappet lifter ?
so something with a bit of a radius is to all intents and purpose a flat tappet ( rocker , follower ).Lifters that are flat steel against the cam lobe, there is no roller bearing as in a roller cam
