[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
A few finishing touches still needed, but these are the winter covers that I made for the engines.
They are made from some left-over materials that I had from my upholstery business.
I plan on putting a draw string at the bottom to tighten the fit. I managed to make these on the Admiral's sewing machine, since my machine is a bit of an effort to set up.
tpenfield
Finishing touches . . . I got the draw-strings installed.
Earlier today, I ran some PG antifreeze through the flush port as planned. Then secured the covers . . .
There are some 'stock' covers available for these engines, but I saved $350+ Beer Bucks 🍺 going DIY, and made them so they cover the lower portion of the cowling to a greater extent..
I have 2 covers shipped with my old chap but they were to small for the Mercs, and no way would fits yours, most likely were for Yam's. Sooner or later I'll find a use for them
tpenfield
Yes, I used 4 yards of 54" wide material for each engine . . . a lot more than I was initially thinking. I also made them a bit bigger than they needed to be, figuring it would be easier to 'snug' them up if needed.
tpenfield
Pole barn.
Not sure they allow those where Ted lives
Probably, with enough land, a barn could be built . . . but I'm maxed out on what the house/land can do.
There is a place right near the re-power shop that is called "Boat Loft Condominiums" . . . For a mere $200K you can own a high-bay unit to store your boat. You can also rent similar spaces for $2,400/month (+/-).
I think I'm good where the boat is . . . in my driveway . . . $0 incremental cost. :LOL:
