Floating Dock question
JASinIL2006
Hi all, we are considering adding a floating dock section to our current land-based, permanent dock. The current dock is wood construction resting on a crib filled with rock. It is quite stable and is about 20'x25'.
Our lake is a small lake (3 miles long x .75 miles wide) in Northern Ontario, Canada and our cabin is a small cove on the lake. The lake freezes completely in the winter.
We want to add some floating dock sections to extend our dock into the lack and to proved places to dock several boats (e.g., 20' pontoon, 19' bowrider). At a minimum, we're probably looking at floating sections that would be about 5' or 6' wide and that would project into the lake about 25' from the permanent dock. We're thinking about a system like EZ Dock (https://www.ez-dock.com/product/60-dock).
As we consider this, we have some questions. First of all, we've seem some things that suggest these floating sections could remain in the water over winter. (Supposedly they float above the ice and and immune to the kind of spring thaw damage that tears up fixed docks.) Not having to move the floating sections to the shore would of course be a big plus, especially as we're getting older.
A second question has to do with how (or how well) these floating docks connect to permanent dock. I assume some sort of hinged gangway would be needed to allow for fluctuations in lake level (not a huge issue on our lake, but we sometimes see water levels fluctuate 12-16" over the season).
Anyone with experience using these types of docks?
Thank in advance!
Jim
I have 2 EZ ports (used for water craft) which are made by EZ Dock, they have been in the lake which has frozen over and have had no effect. They are mounted to my Marina floating docks. They don't go very deep into the water so the freezing just pushes them up.
That said, I have no first hand knowledge about the dock sections
rolmops
The tricky part is the connection between the permanent and the floating docks. The floating sections will go up and down with the lake level,while the permanent dock does not go up or down. On top of that, the permanent part is stable , but the moment you step on the floating part things move around and up and down.
Lou C
Our beach association has a floating dock but it is removed at the end of each season, even though the dock is free to move up & down with the tides.
We get freezing but it rarely freezes solid.
Scott06
Thank in advance!
Jim
I think it depends on how hard the ice freezes up on your lake. We boat in update NY and the heavy ice floes will move the shallow water buoys that have two huge concrete blocks for anchors.
Not a huge data set but my brother bought a drive on floating lift from gulfstream two years ago.
for him it works good as he has MS so is mobility impaired and this allows him to get in and out of the boat somewhat easier. We had 4 x 1.5" galavined piles drive into the lake to hold it in place , and I made a aluminum hinged gangway that ramps down off the permanent dock onto the floating section. This is just a aluminum angle frame with expanded wire decking welded to it and a piano hinge at the connection.
Our lake is different maybe than yours are they let several feet of water out to prevent flooding in the spring. So there is a layer of water and frozen slush on the lake bottom which presents no issue. We had insanely high water first week of april that ended up driving a bunch of trees etc into the lake and gave us the second highest recorded water level that left 40 cu yds of chit on the shore.
Bottom line 'Id be hard pressed in that northern climate to leave anything made of $$$ plastic in as you never know what nature will toss at you. Probably fine on a normal year but the once every 5-10 year ice or flood may mess it up
Not sure what your lake shore looks like but since they float can you just drag them up on shore easily? We have done all sorts of stuff over the years bringing in hoists and docks- 12 vdc winches , rope to the lawn tractor/ car whatever. Neighbor has a ranger UTV and I bought a JD compact tractor last spring both work way better than our older GT235 lawn tractor for this work and taking the jetski in and out of the water
aspeck
We get frozen water in central PA and the marina with floating docks uses ice eaters to keep the ice from crushing the floats.
Not sure in ontario, however I know of places where a dock regardless of construction must be removed as the lake is part of a snowmobile trail.
There may also be permitting required for a year-round dock.
JASinIL2006
Scott, I don't this is a concern on our lake. I believe the only snowmobile activity on our lake is people crossing the lake to get to the few winterized cabins on our side of the lake (which is the opposite shoreline from where the road access is to the lake). Our lake is pretty deserted once it's iced in.
Our options for winter are either leave the dock sections in (if they won't get damaged) or pull them up on shore. We currently have some floating dock sections that are entirely wood construction with many 2" sheets of pink insulation board. Every year, we haul them out of the water when we leave at the end of summer, and then reinstall them next Spring. They are very heavy and it is a multi-person task to pull/winch them up on some skids I built at the shoreline. They also are needing to be replaced, which is why we're looking at EZDocks as an alternative.
I think maybe I need to contact the company and see what they advise. I'll report back in case anyone is interested in what they recommend.
