9.5 Evinrude
rjphillips
I was looking for a starter for a 1967 9.5 Evinrude. My grandson has a hard time pull starting the moto
tphoyt
You may want to try the Johnson/ Evinrude section for better results. A MOD my come by and move it for you to that section as well.
Best of luck
Yes, he needs his Wheaties.
I used to pull start my '58 Fat-Fifty. To be fair, there was a technique to it.
saltchuckmatt
I don't work on motors that old but if it has the "big gear" like the ones from the 80's my trick is to pull the rip cord out as far as you can and spray a half a can of wd-40 inside the recoil. After that work the cord slowly in and out 10 times or so and see if it improves. Not aware of any starters for that motor and since no one else said where to get one I image there isn't any or their very tough to find. Hope this helps.
flyingscott
I would look for a newer 9.9/15 with electric start pretty common and reasonably priced.
rjphillips
Thank you I will try that
