No he doesn't.
If a customer walked in with this question, I would call Merc tech support.
My guess is that the 6.2 ECM might work OK with a Bravo. Inboards have shift assist strategy in the calibration because inboards props usually have more bite on the water. So there might be some engine flare when shifting a Bravo -- not sure if that might cause issues with the cone clutch. There also might be some issues with the inboard fuel and ignition maps. Inboards don't trim out.
Probably won't be able to "reflash" the ECM. The computer diagnostic system (G3) isn't really set up to do this. It needs to see what the current program loaded is and only looks for more current calibrations. It might be possible with help from tech support, but why would Merc want to do this for free? It's not in their best interest.
I could see this needing about $2500-$3500 per engine in parts, depending where you source them. Plus another $2700 per engine if you need new ECMs.
You will need to do a bunch of research, this might not be a easy swap.
Quick possible list:
starter, flywheel cover, coupler, maybe flywheel or move ring gear, shift bracket, front motor mounts, cooling hoses and the P/S pump might need the alternator moved, so there might be new mounting brackets.
Maybe you can reuse some of this stuff from your old engines?
BUT, if you can do it on the cheap ---- a pair of 6.2s might really turn your hull on!
