DeepCMark58A
- Joined
- Aug 17, 2015
- 3,623
Not helicopter parents or grandparents but there is nothing we will not do to be there to help and support.
Got to love it.So I had a Dr appointment this morning figured I since I was in the city I figured I would get my oil changed. I hate valvoline rapid oil change, I know all the managers are forced to follow a script and have quotas to fill but just stop. You have my vehicle on file you have my name an address put it in your customer notes to do not try to upsell me I have a 2026 Silverado, my computer tells me what the filter life is, what the tire pressure is etc do not offer to check my cabin filter I know what the status is. Even when you roll in and tell them just an oil change they still persist.
Years back, my wife had a Honda Civic manual trans that used automatic transmission oil and they did recommend changing it at 100K.....her first CRV was in for an oil change at about 90K miles. The dealer recommended changing the timing belt because if it failed it would take out the valve train and ruin the engine. I had them hold off at that time so I could get that researched. As it turns out, Honda switched to a timing chain some years earlier, but many dealers were still gouging people for a service no longer needed !Got to love it.
Same type of situation as you. Always trying to up sale.
Last time I was in, the attendant said Honda recommended an automatic trans flush based upon the current mileage.
Mind you, the guy talking to me through the window while I’m sitting in the driver’s seat.
Asked him how do you flush a 5 speed manual as I pointed at the stick….he had no answer
Not only are they crooks, but 864 bucks? My local mechanic did the rear brakes on my Cherokee with new pads and rotors and emergency brake service for half that amount. Midas is one if the higher priced places in our area and they were only 640 bucks. Your dealer is outrageous !!Thanks for this thread, I also need to rant...
I had to take a new to me, 12 year old truck in for a recall. I hadn't been to a dealer in 10+ years, only to get additional keys made for a previous truck, another story.
In addition to the recall, which was nothing more than a computer update, they had to do a "multi-point inspection" while it was there. In the end they came back with it needing every fluid changed, all based on age and milage, with no knowledge of previous service. The truck has 70k miles on it despite being a 2014. brake fluid, coolant, tranny, diffs, transfer case. Also recommended was spark plugs and notably, rear brakes, which were measured at 3mm remaining. They wanted to do the brakes right then because they "required immediate replacement." they quoted me 864.99 for rear pads and rotors. All this is documented on the paperwork. I told him no thanks, I do my own wrenching.
Anyway, I assumed they were not lying to me so I ordered up some pads and rotors and finally got to them last week.
Here's a pic of the old pad and the new pad.
Why do I want to bring them into the dealer and throw them at the service guy?
