Boats from work.
MikeSchinlaub
I got in a rush and didn't take pics, but the blue Nitro is done.
Hamby stand.
The port side ratchet rope was pulled out almost all the way to the nose, and the pocket for the cover ratchet was ripped open, so I just had to zip tie it so it wasn't loose and flopping around. Also no poles, port side center cover strap was broke and had to be tied to the frame, and star side was just gone.
Next is a red Nitro. These are the only pics I have right now, but I ground it yesterday and glassed today. Beave (supervisor) said the hull was all stressed out too. I'll have to look for that Monday.
MikeSchinlaub
is the black in the last photo primer ?
No, black gel. You always spray black under flake, it helps you see that your flake has covered well, and prevents a weird look you can get from spraying flake over clear. Usually, you just need a coat of really thinned down black right before yoy spray the flake, but I like doing bigger jobs like this because I can fine tune the bodywork with it.
MikeSchinlaub
So, Thanksgiving vacation is going to be a bit wonky this time. We didn't have the flake, so boss had to tell the marina to order it. They got it in yesterday, and he went to get it this morning. The problem is, by the time he got back, I wouldn't have time to spray 3 colors. So, I'm off today, and I'll go in Tuesday to spray. I already did what little there was to do on the other side, just a bit of buffing, so wouldn't have anything else to do anyway.
Scott06
Thats a lot of work. My other hobby is restoration/muscle cars and people dont understand how many tough hours go into paint and body work. I dont paint cars as much any more like in my younger days but man it is a lot of work, and you cant take any short cuts or it looks like chit.
Years back I had lifting issues on a 74 buick lesabre I was painting for a family friend. The Dupont Chromabase (was a relatively new system at the time) was lifting the 14 paint jobs that were on the car already ... I ended up painting it 3 X's before I figured out what sealer I needed to keep it down. Made no money on the job
MikeSchinlaub
All done with the flake. I think it looks better without the white stripe.
Scott06, chromabase is what we had when I started, now we have Cromax XP. Honestly, I liked the chromabase better. The xp covers better, because it's 2:1, but there are hardly any chips we can use because 90% are metallic. So now we have one of the cameras, but I swear it hates me. Everything I've ever tried it with took at least another 1/2 a day to match.
Scott06
I figure the paint systems get modernized . I tended to lean more to the PPG side of things . I painted my 65 GTO back in 1992 with PPG Concept sing,e stage. Man did that paint system hold up well. Sandblasted the entire car as it sat outside for a decade before I got it and covered with surface rust. Started with DP epoxy primer on the bare metal. built up Kondar lacquer primer, sealed on top coated with concept. I should have used different primer as that layer of paint is now brittle and is flaking if you nick it. The DP epoxy primer virtually eliminate any rust back over the last decades, really impressed me. The concept where I got a run or two was virtually impossible to get the run wet sanded out it was so hard. I was working at the local PPG paint shop so I got a discount, back then I thought the gallon of concept was pricey at $135 , miss that pricing now … when I did duracryl lacquer jobs on any daily drivers I could soup to nuts paint a car for $300-400 bucks all in. Now I think I was looking at $2 k in materials to redo my GTO…
Pmt133
When I was in college my one classmate, a graduate student, worked for Dupont. I jokingly asked him what he thought of PPG expecting some snide remark. His response was they are a top notch company with an excellent line of products. He felt Dupont did some things better and that PPG did others better depending on the product line.
Both are way out of my price range lol. My uncles 67 was painted in oem ford kona blue, which is believe was PPG.
