.If you have to do an engine rebuild, you can convert it to Vortec heads, 4bbl intake and add an Edelbrock 1409. Money yes but probably worth it if the old heads have to be redone anyway.
You are right to ,focus on the floors transom and stringers. The engine is easy if the structure is ok..
Thank you guys, for all your feedback on the engine picture.
It seems unanimous now that this 5.7 is a pre-Vortec with a 2 barrel carb.
I was prepared to take a chance and drive out to thoroughly checkout the boat.
But I was really hoping it was a Vortec with a 4 barrel that I could enjoy rebuilding.
The rest of the boat looks pretty darn nice, especially the original upholstery.
If I had encountered soft floors or transom I would have passed on it anyway.
.The easiest way to tell is that a 5.0XL and a 5.7 XL are 4 bbl carbs, a 5.0 and 5.7 are 2 bbl. The XL is the difference assuming it is the original flame arrestor cover, thats where it usually spells it out. Charlie
of course he meant LX , XL is his shirt size....
Did you mean to say "LX"..?
I don't think I've never seen "XL"...
Just remove the dang cover
ok Captain Obvious.
Yes that should be fine if propped correctly. 220 hp As is. Michigan motors can set you up with an edelbrock 1409 and they sell a reasonably affordable cast iron 4 bbl intake. You can use this throttle bracket.
Here is another possible candidate. This one is in a 1998 180 runabout.
Would you guys agree this one appears to be a Vortec 5.0 with a 2 barrel carb.?
I would most likely pursue uprading it to a 4 barrel manifold and carburetor.
But even with a 2 barrel, it should move along pretty well in a little 18 footer...
