Beautiful Old Merc - Not Mine
Mc Tool
If it is a 1931-1978 motor, it requires a 10:1 mix. Later engines can run 25:1. TCW-3 is the recommended Oil
yeah 1931 - 1978 they didnt change , and yes it is 10:1 apparently more to aid sealing the main seals ....such as they are . Dad bought one new in the mid 70's and that was ½ pint to the gallon , the fuel cap had a bit of about 1¼" brass tube on it that when inverted held the correct amount of oil for a tank full of fuel .
I have heard stories that some were used on troop folding landing craft during the war , apparently they can still be found buried on the beaches ...
Berdink
I read for reverse, the motor itself could run backwards.
Mc Tool
With something ( 2 stroke ) at or near tdc it will run backwards .
I seen it on a motorbike ( Frances Barnet ), unbeknownst to the piolet it started on a backfire ........shoulda seen his face ....all leaned over the handle bars revving the crap outa it in anticipation of doing an epic burnout , dropped the clutch and it reversed onto some stuff at the base of the shed wall , climbed the wall and landed on him :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
jimmbo
That was how the Dockbuster did Reverse. Made for a complicated Distributor Linkage, required Multiple Solenoids to turn the Starter in both Direction, and a Double Bendix for engagement. Rope Starting one of those things was not easy as well as Dangerous, as you not only had to overcome the compression(which was quite easy with 6 small Pistons, but you were also rotating a 12-13 inch Diameter Prop. When that baby fired, the boat was moving, and you could end up out of the boat, if you were Lucky, if unlucky you were on the Flywheel
Mc Tool
Some big old diesel marine engines had some way of reversing rotation for reverse
boscoe99
My dad had one back in the 50's I believe. Start it in forward or start it in reverse. Starter motor determined the direction of rotation.
I remember folks telling my dad he was crazy for having that much horse power.
Berdink
Like people in the 90's saying a 500mb HardDrive was way more than you'd ever need.
Mc Tool
My cell has twice that, 512gb....and was available w 1TB....
Hell , I didnt even want that much ....the old one had 129 gigs and I only used half of that , but you go into the lap top shop ( :LOL:) and tell them you want 4 gigs of ram and 129 of hard drive and watch them all smirking at each other " oh sir , they dont make them that small anymore "
This ones telling me I have "175gb free of 237gb", and my broadband is slow so Im no better off .
The old one started billowing out smoke and burst into flames just as I flung it out on to the lawn .:oops:
jimmbo
What , like you cant remember where you left something ....happens to us all jimmbo , aint none of us getting any younger :LOL::LOL:
No, I was referring to a post of a phone having 512gb Memory vs the Com 64 having 64kb. The Com had 64k of RAM, while the iphone has 512gb of Storage, not Memory
