Oil Lubed Hubs
shinytopgeezer
I've only owned two boats and trailers over the years and always enjoyed them. All had standard grease hubs. I've also owned several over the road tractors and trailers. All those had oil lubed hubs. Never had a failure or maintanence issues (except the Mack! ugh, it broke me.). Anyway, I was looking at EZLoaders web sight the other day and noticed they have oil lubed hubs as a option! Has anyone upgraded their own trailers to these hubs? And who makes the conversions? With the RIGHT seals should be ezy-pzy! Thanks in advance. Great web site guys. We "vicarious" boaters are depending on you!
My new trailer has oil bath and made by Dexter
Searching web for "oil bath hub conversion kit" and can find several. Here is Kodiak kit
Figure as long as the spindles surfaces are in good shape they should have no issues
dwco5051
I have had both sixty some years ago. Had a couple of bearing failures (BIG $$$) with both. A seal failure on a packed grease bearing will usually give some visual signs with grease slung out from the bearing. A failure on an oil bath can cause failure within a hundred miles. I live only a few miles from interstate 80 and our local fire department handles at least one or two trailer fires a month and I think that the oil accelerates a fire caused by a hung up slack adjuster. Packing just the trailer axles was an all day job if you owned the equipment. Back in my days every stop for meals or fuel also was a complete walk around with the tire billy, feel all the hubs for heat (before hand held IR guns), and check oil level in sight glass. I can sit in a restaurant today and never see a driver do this either right after stopping or before leaving. If you drive in flip flops wearing shorts you have to rush back to that air conditioned cab with your automatic transmission.
Sealed grease packed roller bearings are good enough for the railroad and they are also good enough for my boat and light equipment trailers. And yes many companies including Dexter make wet bath bearing kits.
Stinnett21
My boat trailer was new in 2003 with UFP oil bath hubs. They lasted 15 seasons. Boat was always towed, often 3 hour trips to lake and back. Boat had 1,300 hours when the hubs were redone in 2019. I went back with grease hubs only because the spindle surfaces were getting worn.
shinytopgeezer
Thanks all for the replies! Good reading. Thanks for the link alldodge, very informative. And Stinnett21, your history with the oilbath was great. The worn spindle surface must've been on the seal surface? Did you ever have water in the hubs? It's so common with the greasers I'm curious. Also odd since the lower units on the drives spend alot more time under water than the trailer hubs and seldom have water problems. And the proplers spin alot faster than the trailer wheels!!! Well, except for Scotts!!!😃
Lou C
Oil in some ways would lubricate better than grease but the issue is leaks, you could go from good lubrication to almost nothing due to a leak, especially at highway speeds.
Grease is certainly adequate though, look at it this way:
greases have improved, a LOT from the old days...
Back when I started working on my own vehicles, front wheel bearings on rear drive vehicles, had to be repacked every 36,000 miles or 3 years.
Then much later came permanently lubed wheel bearings, on both rear drives and 4x4s. I have 3 Jeeps that have that kind of bearing, lubed with grease and I have not had to replace any of them yet!
1998 Jeep Grand Cherokee: 186,000 miles
2007 Jeep Grand Cherokee: 137,000 miles
2017 Jeep Wrangler: 168,000 miles
based on all this, I'd stick with grease!
Lou C
Oldsters here remember that nasty, evil smelling yellow Castrol or Quaker State grease in the tub that you had use to hand pack bearings back in the '70s? Some of the pages of my VW Idiot book are still stained with it lol.
bought this and starting working on my VWs in the spring of 1972, ancient history!
dwco5051
Did you ever have water in the hubs? It's so common with the greasers I'm curiousnks . Also odd since the lower units on the drives spend alot more time under water than the trailer hubs and seldom have water problems. And the proplers spin alot faster than the trailer wheels!!! Well, except for Scotts!!!😃
The water intrusion on axle seals I believe is more often caused by the partial vacuum caused when the warm to hot (if it has trailer brakes) hubs are suddenly cooled by being submersed in cold water. Not the same circumstance with a lower end.
Mc Tool
Nah ,not the same but the seals should still be able to cope with that pressure difference . I watched my neibough fitting new hubs and stubs to his log splitter and no matter what I said he still installed the inner seal wrong ....now I know he's not going to be dunking it in the lake but .....
Stinnett21
Yes a few of the seal surfaces were getting striations. I tried to smooth them out with emory cloth, etc. I didn't notice water infiltration till 2019 when they were all redone to grease. The UFPs required removal of the wheel and then a set screw to drain the oil which I did every season and replaced with 50 weight.
dingbat
Took a deep dive into the various hub lubrication systems when I bought a new aluminum trailer a two years ago.
I looked at Kodiak oil lube but had concerns about catastrophic failures. Went with torsion axles with Vault system hubs which came with a 5 year, no service warranty.
You can get around the issue using oil instead of grease seals.
Oil seals are typically rated to 7 psi. Grease seals are typically rated to 3 psi. The trade off is of course price. The oil seals I use are $20 each
I have a 28 year (think would need to look at Reg) old 10 ton Tag trailer with oil bath axle. They have never leaked and our Dexter axles. Dunked them maybe 8 to 10 years ago getting a hydrohoist lift. No isses
redneck joe
a common theme in this thread is 'seals'
potato, tomato, 200, 221 - the seal seams to the the common denominator in the success of a bearing and that comes from maintenance to catch the common denominator before it becomes catastrophic.
