Everything turns off
Davc661
If I turn my bilge pump or aerator on my depth finder turns off. Bass Tracker classic xl and the pumps don't work
Welcome
I would start by cleaning connections beginning at the battery terminals. Corrosion on a connection which feeds others will drop the voltage to low to operate, can also be corroded contacts inside a switch
You are likely experiencing a loss of voltage or ground. You therefore need to check both wires for corrosion. Corrosion can occur under the insulation so check for bulges in the wire.
Mc Tool
Volt drop test , volt drop test , volt drop test ....any one who likes to do their own maintenance on their vehicles can save themselves a power of time, guesswork , headaches and money learning how to do this test . Google it up and get your head round it ...its not hard .:D:D This test will allow you to pin point the fault ....oh , and consider also there may well be more than one fault....so if you do find a fault but things are still not right ....keep looking . It stands to reason that if you have one corroded connection in any given application there is likely to be another too .
redneck joe
what he said.
welcome to the forum.
