Grease Question, compatibility of different greases?
crazy charlie
Hi guys, I grease everything with Wallyworld marine and wheel bearing green grease. Gimbal zero, bell housing zerk etc. grease gun broke today and the only other grease gun I have is filled with Lucas Red and tacky. I am aprenhesive to pump the red and tacky into the green marine grease zerks. Do I wait till I get a new gun to keep the green grease going or should I pump some red and tacky into the zerks and wait for a new grease gun for Christmas ? Just concerned about compatibility. BTW my wife would really love to get me an easy gift like a grease gun ....would make her gift list easier for sure..lol
froggy1150
Ensign
I am going to assume wallyworld is a nlgi2?
I dont like to mix grease because it's hard to judge what is compatible. The red is a synthetic nlgi2 with additives. Is a $5 grease gun worth your time and $$$?
Might be ok
jlh3rd
NLG ratings don’t define compatibility.
”BASE” determines compatibility.
lithium…aluminum complex…..calcium…others are all bases.
some different bases can mix, supposedly. There are compatibility charts but I’ve also heard those charts can be wrong.
so, do diligent research.
Gee, wait for the new grease gun and continue with the Wallyworld stuff. I think the red and tacky is a lot heavier than the marine grease you have been using.
Heavier grease is not always better, and it does not flow as well, and that red and tacky stuff is really stiff. If you had a piece of road work machinery with really loose bushings or an army tank that needed grease, the red tacky stuff might be good.
Scott06
They are both lithium complex greases and compatible wouldn’t hesitate to mix them. For this or other grease compatibility concerns you can look up what type of greases they are and if they are compatible types.
mike_i
Do a search for a grease compatibility chart.
Texasmark
I too have read about different based greases may be incombatable......so I always wondered what difference does it make if grease A and grease B don't homogenize????? They are both lubricating the surfaces.... jam up against each other, unless there is some kind of difference in the chemistry where one changes state due to some environmental difference to which it wasn't designed......and what does it do, get hard, get runny and flow out of the area?
There are different types of grease. My father had a can of grease with some sort of fibers embedded in it. It was very stiff compared to the lithium grease of that period. I would not use that kind of grease now, but back then (mid 60s), it was used.
Scott06
yes The grease basically comes apart and separates back to its previous components oil and a carrier/ binder That thickness it to grease. I think one or two of the combos thicken it but one would have to read up on it
Lou C
I think that's the stuff I used to use in the '70s when I had my air cooled VWs, as I recall it was nasty smelly stuff (Castrol or Quaker State?) Yellow stuff.
Lou C
A couple of OEM trailer companies use Red & Tacky, I know for sure that Venture does and so does Coyote trailers. My brother had a 2021 Venture and has a 2023 Coyote now both had Red & Tacky. It's a lithium complex grease.
