Re: HELP!!!!!!!!!!!
Jorge -- The prior post makes good sense re. the ignition switch. If the key switch has a "run" or "on" position, the switch would have to be in that position in order to permit you to start the engine manually. If, however, the key switch is used only to engage the starter (i.e., no "run" position), then the switch would be irrelevant to your ability or inability to fire up the engine manually. Some older models have a starter button which engages the starter circuit -- circuit would be irrelevant to manual starting and running. I wish I had my old Lark, now, just so I could go out and check whether the key switch had a "run" position.<br /><br />Interesting.
