engine cover
hondo
I have a 1977 75hp evinrude that could use a new engine cover. Any ideas where I might find one? If I could at least get the gasket that goes around the bottom so no water slips in I would be happy. The model number is 75743.
Bob_VT
Re: engine cover
There have been allot of used engine covers on ebay...even a Johnson will fit. Some need paint and decals but any sign shop will "normally" make the matching decals.<br /><br />Bob
Franki
Re: engine cover
I fixed the holes in mine with fiberglass putty, sanded it back and coated it in etch primer and spray painted it.. looks like new..<br /><br />And for the seal around the base, I used the trim from the back door of a s-wagon car it holds the hood lining in place and looks like flexable C channel.. looks better then new, and works a treat...<br /><br />worked out at less then 30 bucks to fix it up.. and it had two holes and lots of scratches.<br /><br />give it a try..<br /><br />regards<br /><br />Frank
