thump and jolt from 1997 evinrude 6hp at wot
smalloutboardsarecool
at wot my moter has this thumb and jolt every five seconds? what could it be. I have checked the bear lube, the propshaft, the prop, the cotter pin, the platic cap, and the shear pin? I did take out the gears behing the propllor and this little rod fell out,it was the shift rod and rounded at one end. Did I put this rod in backwards? what way does it go in???
Re: thump and jolt from 1997 evinrude 6hp at wot
can someone help is it the worm gears? could it be?? Please helpo :confused: :confused:
fireman 757
Sounds like your dogs are worn. that shift pin needs to be replaced.
can you please tell me were to get these, are there pictures I can look at to see? I took thing apart today and the gears were not worn. were do I find more gears the little rod in tacked what way does it go in?
