1977 85 hp evinrude v4 how replace water pump?
HBF4
I'd like to start out by thanking those folks who helped me last time around. I changed the plugs, charged the battery, and it started right up. That was a cheap fix. Now I want to change the water pump. I have the 1977 evinrude service manual, but it is written to tear down the lower unit entirely; I just want to replace the water pump. It's manual shift, and model 85799s.
alcan
Re: 1977 85 hp evinrude v4 how replace water pump?
Hi HBF<br /> Just follow your manual. Only do the procedures that pertain to the water pump. My advice is for you to read the book three times. Then begin the job.
D
DJ
Guest
HBF4,<br /><br />If your manual tells you how to tear down the lower unit, it must tell you how to get it off/on.<br /><br />The water pump sits directly on top of the L/U.
HBF4
I looked over the manual, and this shouldn't be a problem. Thanks.
ledgefinder
Ensign
This is just some notes to go along with the factory description. <br /><br />Pull carbs (clean 'em while they're off), disconnect shift linkage under carbs, remove the 6 (?) nuts holding the LU to the mid-section, pull the LU off. Be careful to save the plastic tubes that act as guides for the water tubes when you re-install the LU. Also, be careful not to thread the shift rod up or down on it's threads - it wants to stay the same length. <br /><br />Once the LUs off, straight-forward to pull the pump top off & replace the impeller. A little grease or lube on the impeller vanes will help. By the way, a new impeller, if dry, can be wicked hard to turn within the pump housing - first time I encountered it I thought the LU was locked up.<br /><br />If you want to be real thorough, pressure check the LU while you have it off, or just go ahead & change the prop shaft, pump, and shift rod seals. <br /><br />I have used a shotgun brush to clean out the shift rod tube on engines that've seen a lot of salt water. Other than that, re-assembly is just like the manual, and you need a helper. Here's where you re-use those plastic tubes, by the way.
