year of motor
mary1234
how do i find the year of a johnson boat motor,<br />with only the serial no.?
ob
Re: year of motor
Mary ,Post hp of motor ,if known ,and what numbers you do have and someone will assist.The model number is usually required.Look on motors transom bracket and also on engine blocks silver welsh plug for additional numbers.
mary1234
Re: year of motor
the serial number is FL0470016W<br />AND IS A 6 HP THANKS
Bear
Re: year of motor
This is some kind of a joke I guess.
Bear
Re: year of motor
That is not a Johnson model number.<br />...and your from what you wrote in your profile.<br />If it isn't a joke and you have a model number you'll find the year here:<br /> http://www.marinshopen.se/guide/guide.htm <br /><br />If you find the model number (not the serial number) and still can't find out the year, post it here and someone will tell you.<br /><br />If you don't have a model number, describe the colour and propeller; number of blades, exhaust thru prop or above the prop. Can you post a picture of it?
mary1234
Re: year of motor
o.k. so does anyone have an ideal on which motor <br />{brand} that it could be? person that sold it, said this was it
mary1234
Re: year of motor
yes, the propellar blades are white and it has two. so do you think it is a 1968?
Bear
Re: year of motor
No not really. I just want to make sure it is a 6 hp Johnson. I think you narrowed it down a bit.<br /><br />So you can't find the model number? It should be where you found the serial number. Also look under the cowling, on the powerhead, for a quarter sized aluminium plug for the model number.<br />Possible model numbers: <br />1965 CD-CDL-22 <br />1966 CD-CDL-23 <br />1967 CD-CDL-24 <br />1968 CD-CDL-25 <br />1969 6R69-6RL69 <br />1970 6R70-6RL70 <br />1971 6R71-6RL71 <br />1972 6R72-6RL72 <br />1973 6R73-6RL73 <br />and so on...<br />The "L" is for long shaft. You'll se either<br />like CD-25 or CDL-25, 6R69 or 6RL69 and so on.<br />I have a 1965 short shaft, CD-22.<br /><br />I hope you find the number :)
mary1234
Re: year of motor
well we found another no. it is J3058505<br />WE WILL KEEP LOOKING. THANKS FOR YOUR HELP :confused: :confused:
