Re: Swapping 97 Evinrude 50hp for 86 40hp Evin. and need info on oiling mods.
The motor should come with the VRO pump system except for the remote tank. The remote tank sensor was change, and the 86 tank sensor, may not be correct for the 97 motor, dealer should verify this. What ever you do , you should verify the alarm system is working, should have three functions overheat, no oil being pumped, low oil in tank. I would also remove the starter and check the VRO pump pulse hose and clamps.
