6hp Johnson Trolling motor
AFDan52
Hi all, I have a question? I have a Johnson trolling motor 6hp MODEL# CD-25H Serial# J2959595. I am wondering about what year it might be and should it have a pee stream? It runs fine, but it doesn't pee. Does this motor have an impeller? I haven't bought it yet, and if it is not a big deal to fix iwill buy it.<br /> AFDan52 :confused:
JB
Re: 6hp Johnson Trolling motor
Howdy, AFDan.<br /><br />I think your engine is a '68.<br /><br />Good luck. :)
alcan
Hi Dan<br />Your model does not have a tell tale indecator (pisser). It does how ever have a t-stat in the cooling system along with the water pump. You should also get water spray out the exhaust relief port on the back side of the mid section nearer the top. This may be intermitant do to the opening and closing of the t-stat. When buying a used motor from a privite party I assume that I'm going to have to put another $100. bucks into it. I'm talking nice motors here not junk. By the time you change gear oil, service cooling system, ignit parts, spark plugs, a manual, etc. Bang there goes a C-note. The good news is you know what you got when your done. When you get to the lake you can fish.
AFDan52
Thanks alcan for the quick response, I know the motor is in very good condtion and was taken care of. I remember the guy telling me that he had changed the T-Stat last year. So now at least I know that I don't have to worry about the pee hole. Thanks again<br /> AFDan52 :D
