Re: 6hp Johnson Trolling motor
Hi Dan<br />Your model does not have a tell tale indecator (pisser). It does how ever have a t-stat in the cooling system along with the water pump. You should also get water spray out the exhaust relief port on the back side of the mid section nearer the top. This may be intermitant do to the opening and closing of the t-stat. When buying a used motor from a privite party I assume that I'm going to have to put another $100. bucks into it. I'm talking nice motors here not junk. By the time you change gear oil, service cooling system, ignit parts, spark plugs, a manual, etc. Bang there goes a C-note. The good news is you know what you got when your done. When you get to the lake you can fish.
