Hi installing elec fuel sender unit in tank.<br />Which is the best way to point float.I ask this because looking at boat on trailer tank is tilted back same as in water. I would like to get reading as close to true as possible.Thinking about cruising and use level to see where level is and use wedges under tank to correct gauge.Instructions say to run float along lenth of tank, which is correct when level,but when under way most of the fuel has to go to the rear of tank.has any one solved this problem or is it the way it is.<br />thank you from down under.. Flips
