Evinrude 75 hp acceleration problem-where to make adjustment?
regan103
I looked through the message list, but did not see this problem come up before:<br /><br />When I accelerate quickly from a stop, my 1978 Evirude 75 hp wants to bog down and die. This happens almost every time. I have no other problems, the motor starts and idles fine. If I choke it momentarily when it wants to die, it gets past the point of bogging down and accelerates to max rpm without any other problems.<br /><br />How and where do I make the adjustment to relieve this problem? Someone suggested that it may be set too lean based on the fact that choking works when it wants to die. <br /><br />Thanks for the help.
trumpetbucks
Re: Evinrude 75 hp acceleration problem-where to make adjustment?
The "too lean" theory could be right. I would try adjusting your high speed mixture a little at the time and see what you get.
regan103
BoatProject:<br /><br />Do I make the adjustment by accessing the high speed orifice plug on each carburetor?<br /><br />Thanks for your reply.<br /><br />Bob
regan103
