steviecops
- Joined
- Oct 3, 2003
- 585
Hi<br />In a few weeks time, I'm going to overhaul the water pump on my engine. As I've read on here that some of the bolts can be a job to get out, today I tried them all to see if I would have problems when I come to drop the lower unit.<br /><br />The two bolts that hold the trim tab came out easily, but I couldn't get any movement on any of the four which hold the lower unit on. They don't look corroded on the outside, and are still shiny silver.<br /><br />Is there anything I can do to try to loosen these four bolts over the next few weeks? I really don't want to have to use brute force if I don't have to, and using heat scares the hell out me!<br /><br />I've given them all a good squirt with penetrating oil, but as you can imagine, I can't get it to soak in as the bolts face downwards! There isn't enough room between the bolts and the cavitation plate to use an impact wrench either.<br /><br />I was thinking of moulding some clay or something into a bowl around the bolts and filling them with the penetrating oil, in the hope that capilliary action might get some onto the threads. Is this my best bet, or are there other tricks of the trade that can be employed?<br /><br />As I've said, I'm in no hurry and am prepared to try to persuade the bolts out over a period of a few weeks, rather than force them and have to drill them out. Any help and advice will be gratefully acepted.<br /><br />Thanks <br />Steve
