QuikStart
ob
Re: QuikStart
According to my operators manual,lifting the fast idle lever overrides the quickstart feature.Why do you want to bypass it??
Okie
Re: QuikStart
Idle speed 600-650 then sometimes 950-1000, after engine is warm. Thank you.
ob
Re: QuikStart
What does it idle at in the water in gear? One of your engines temp sensor has a white/black wire that signals the powerpacks quickstart feature when the engine is cold.Its suppose to advance the timing a few degrees until engine reaches a predetermined temp(several seconds after starting) and then drop back.Sounds like you are experiencing the opposite.<br /><br />If what you are experiencing is quickstart related ,the first thing I would suspect is the temp sensor.However ,I'm not convinced that the quickstart is your problem yet.Does the engine run fine at all throttle settings in the water otherwise?
Okie
Re: QuikStart
ob, Thank you. I replaced temp sensor and QuikStart is working properly.
ob
Re: QuikStart
Glad to hear . Thanks for posting back. :)
