2 hp Evinrude is starving!
gusser
I have a 1983 Evinrude E2RCTD that sometimes starts and runs well for as long as 5 minutes then dies, then is difficult to start again. I have taken the carb apart (multiple times) and cleaned it as well as possible using pipe cleaners and compressed air. After such treatment it usually fires up for a short time and I think "Ah-ha, I fixed it", but not so.<br />Squirting fuel directly into the carb makes it fire up for a second or two. So I'm pretty sure it isn't getting fuel. <br /><br />Question one: Is there anything besides a clogged carburator that would cause this behavior?<br /><br />Question two: I have found plenty of rebuild kits on the internet, but am hesitant to buy because I don't know what they contain. Do they come with those little plugs that look like freeze plugs? I think my problem may be crud in the chamber just upstream from the low speed jets.<br /><br />Question three: How do you replace those little plugs?
Daniel Beckman
Re: 2 hp Evinrude is starving!
Checked fuel filter, pump on the engine and ventilation on the tank?
gusser
Yes, fuel is getting to the carb. This engine is simplicity itself. Has only a screen in the tank (which is clear) and a hose to the carb. No filter, no pump, and tank ventilation isn't the problem.
gusser
Float appears to be fully functional. When I take the high speed needle valve out, fuel runs out so I think there is fuel in the bowl.
cotester
did you check youre needle and seet sometimes they have to be changed
gusser
Everything that I can see appears to be clean and in good order. I think I need to get to the low speed jets to clean them from the supply side. There is one of those plugs (that looks like tiny freeze plugs) on the outside of the carb just over where the jets are. Do those plug things come with a carb rebuild kit?
ajhmfic
i bought a carburetor kit for a 84 2 hp evinrude and it come with all of the plugs, seals, float, needle valve, and everything that i could see that went inside the motor. it wasn't high at all, $22.00 and some change. i don't know if you can find one for your year model close to you but try a technician that specializes in evinrude products. hope that i helped any at all.
