cvader2000
Thread starter- Joined
- Jun 5, 2004
- 7
Was the steering system for the '67 33hp Johnson (RXE-15S) pulley/cable?<br />The boat I got this motor off of has the "newer" cable/rod type (sorry not sure what it's called).<br />It looks like the previous owner made a plate that attaches to the front of the handle on the motor. It has a small rod that sticks down which the hole in the steering rod slips over then a cotter pin goes in a hole in the fabricated piece.<br />Should I go with pulley system? Is there an actual manufactured adaptor for the other type of steering?<br />Any suggestions are appreciated.<br />Thanks,<br />Charles<br /><br />Here's an attempt to show you the "adaptor".<br />The top 'O' is where it bolts to the motor handle.<br />The narrow bottom piece is where the steering rod slips on. Cotter pin goes in small lower hole to hold on rod. Hopefully this gives the idea.<br /><br />-------<br />|||O|||<br />|||||||<br />\|||||/<br /> -----<br /> |||<br /> |o|<br /> ---
