FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1985 140hp Johnson with a 25" shaft. I believe its a looper V4.<br />Where is the best location to drill a tap for a water pressure gage and what should the pressure be?
Re: Water pressure gage installation 1985 140hp Johnson
Hmmmm. I think your '85 has a tattle-tale (pisser) and I also think all ya gotta do iz tee into that line. If you get the gauge kit from your OMC dealer, it should have instructions. My 200 'rude has about 18psi water pressure at wfo. <br /><br />c/6<br />Hooty
The loopers read water pressure from the adaptor plate which is incoming pressure. On the 1985 you T into the line from the adaptor going to the water control valve. <br /><br />Good luck!
Thanks Hooty/Dhadley,<br /> Now I'm stumped. I thought I knew my motor. I didn't know it had a water control valve. Where is the valve located? Thanks, Dude
