Freezebear
- Joined
- Oct 14, 2003
- 93
Well, I finally got a call from the mechanic today and they said that my case has a leak between the 2 halves that is sucking outside air in and causing it to run rough and not idle. They said this would be about a $1500-$2000 bill. They cannot get to this type repair until after the summer is over. Motor has excellent compression and runs like a champ before this happened. I could save a lot of money if I did this my self because I think the motor is worth it. I also need a new stator plate because it has started leaking potting compound but still tests OK. What should I do? Just how hard is it to pull off this powerhead and break the case apart to change the seals? I have the Clymer's manual but wanted to know from first hand experience how hard this is.<br />
